Hello all. Received a working MBA the other day, along with a new MB to do a data transfer too.
Transfer went fine using migration assistant.
Last night I left the MBA on doing a time machine back before wiping it and installing high Sierra.
Booted fine this morning, stuck in my live thumb drive that has high Sierra to install.
Booted to efi partition - hung on Apple bar screen at about 90%
Pulled thumbdrive and powered off the machine. Switched USB ports, option - per and once the apple dong stops - it dongs again and again.. Indefinitely.
SMC reset and pram reset didn't do anything to help.
Pulled ssd, wifi/bt, battery. Still same symptoms.
Any suggestions on where to go from here?
Only previous work history reported from user was due to 100% full ssd. Had the apple store clear it up for her. I do see some fingerprints on odd places internationally though. Going to pull the motherboard and check for any heat damage/probably bios area first.
Ill keep you guys posted and give you the motherboard number once I get the board out. (820-3209-a)
Update: fan spins fine. Isl sense resistors are ok, no water damage anywhere. Bios resistors are reading what I would expect. Going to bust out the microscope and bv/schem to start checking voltages, but not sure what to look for in this case.
