Hi, I have an imac 27 that has lines vertical blue, red, then try to start system but it gets white screen, I thought it was a video chip, I did reballing, but the same problem continued, so I changed the gpu chip 216-0811000 and the problem continued, I also tried external video, it stays on a blank screen, I also tried good ram memory, any suggestions you can make
