A1534 "DeadCPUBook" 820-00045A Board doesnt turn on
Sn0w3y
Hi Guys,
PPBUS_G3H = 8.56V
PPVIN_G3H_P3V3G3H = 3.28V
PPVBUS_E85 = 20.4V
PPDCIN_G3H = 20.4 (logical)
PP3V3_G3H = 3.29V
PP3V3R3V0_AON = 3.25V
PPVRTC_G3H = 3.3V
PP5V_G3H_LDO = 4.97V
PP5V_S4 = 4.99V
PP5V_S0 = 4.97V
PP3V3_S5 = 3.3V
PP3V3_SUS = 3.3V
PP3V3_S4 = PULSING Between 3.3 and 0
PP3V3_S0 = 3.3V
PP1V8_S3 = 1.8V
PP1V5_S0 = 1.5V
PP1V2_S3 = 1.2V
PP1V05_SUS = 1.06V
Also i found something called a "Matt Card" on the board.. What the he** is this ?..
Guys Help me out
I suppose PM_SLP_S5_L is steady high.
In such case, change U8000.
Just in case, test first disconnecting trackpad (J4801).
Sn0w3y
which voltage did inform you about the "always high state" of this rail ?
Or better said - how did you know?
And this voltage should only be high if "on Button" is pressed?
Only S5 power rails appear before pressing power button; when charger is connected, of course.
S4/3/0 voltages require to start the machine with power button.
As you get stable S3/0 voltages, S4 ones shouldn't pulse, must be steady high too.
Sn0w3y
So if I understand you correctly, the S4/3/0 Power Rails shouldn't be present if no button is pressed ?
And if they are, U8000 could be faulty as its giving out these Lines ?
First time when charger is connected, board should automatically turn on; no need to press power button.
Sn0w3y
Well.. this is the case..
World be almost impossible if S0 is there and S5 isnt right ?
So why do you think U8000 is the problem ?
The other S3 and S0 voltages present?
Possibly bad solders at U8000.
Post diode mode (red probe at ground) for 3V3_S4.
Sn0w3y
PP5V_S0 - 4.98V
PP3V3_S0 -3.30V
PP1V8_S3 - 1.806V
PP1V5_S0 - 1.517V
PP1V05_S0 - 1.056V
PPVCC_S0_CPU - 1.709V
PP3V3_S4 to Ground 0.32V
Ohms Mode on C7830 to ground is 44.8kOhm
Sn0w3y
As you said - i will change U8000 - ordered my Donor Board today as my last one is almost empty :D
BTW:
PPVIN_G3H_P3V3G3H changed to 20.5V is this normal ?
Why do you bother with USB-C input, if already got S3 and S0 voltages?
20.5V is good voltage, no problem.
