papalati
TLDR - Early 2015 MBP Retina was dropped and had liquid damage as well. When plugged in it turns itself on until manually forced off. No display and no external on hdmi as well.
Long story, bought a 13" a1502 Early 2015 and figured it had been dropped based on the listing. Little did I know it was dropped and had liquid damage in the corner near the lcd connector. The indicator in the middle of the board wasn't triggered. It arrived and I plugged the power in and it turned on by itself.
I'm assuming a short somewhere, but the screen stayed pitch black. I should have tried the flashlight trick to see if the backlight was out, but already had the board out by the time I remembered that as I wanted to try a known working board I had in it. The other board worked fine with the magsafe and also the screen obviously.
I've checked the board and the only thing I can come up with so far is a faulty FDC638APZ IC but still waiting for the chips to come in. So, I'm not sure where to go from here on the magsafe triggering the laptop on. Was considering putting it in my ultrasonic to clean it up before I get started again tracking down the issue.
What do you guys think?
