820-3476 - Power but no chime and image
Sykulski
Liquid damage that was cleaned by somebody else.
When power on fan spins - then stops - then spins again and slowly ramps up and keep on spinning
On first fan spin there is 3.2V on pin 5 (SPI_MOSI) and 6 (SPI_CLK) for 2-3 seconds but then drops and does not come back on along with the next fan spin
SPI termination resistors and traces are fine. Replaced U6100 (still have the original) but no dice
5V_S0 = 5.1V
3V3_S0 = 3.3V
1V05 = 1.05V
1V35 = 1.35V
PPVCC = 1.7V
PPVRTC = 3.3V
PCH_CLK32 = 32KHz
Any clues ?
Gurmon
Probably a dead CPU. Other than that no idea.
Have you Ultrasonically cleaned this board yourself. Might be crap under chip.
Sykulski
Pulled SMC and measured termination resistors and traces all the way to the site. They are all good. Replaced the SMC with another one. Still same symptoms :-(
Ugh, well this one is going to suck. Not much more you can do than inspect for corrosion or damaged/missing parts. Mostly around SMC or CPU area
Sykulski
It sucks already :-) I've been looking at all components on this board on maximum magnification for hours :-)
