ytesfay80
I am not getting a green light on the charger but I am getting 16.7 on ppdcin_g3h and 3.37v on pp3v42_g3h.
R7101 is showing 0.48v on pin 1 and 1.4v on pin 2. There is suppose to be 5v on the VDD pins in order to turn on U7100(ISL6259) so I troubleshooted to the U7190 area since that is where PP5V1_CHGR_VDDP is created.
I replaced U7190 with one from a donor board.
Here are some of the measurements I got from the U7190 area.
U7190 voltage | diode mode
pin 1 - 0.64v 0.688
pin 2 - 1.41v 0.003
pin 3 - 3.59v 0.361
pin 4 - 1.58v 0.004
pin 6 - 13.55v 0.56
pin 7 - shows 5v even though the schematic says it's a NC.
I replaced C7195, R7195, R7196 and C7198/C7199 with new parts from mouser. For some reason R7195 and R7196 both measure 155kohms even though they measured the proper resistance before I put them on the board. Is there something that could pull the resistance down?
I get a short to ground on both sides of L7195 and when I remove it and check for the short on the pads I get a short only on the Pin 2 side.
pin 1 - 0.64v 0.688
pin 2 - 1.41v 0.003
pin 3 - 3.59v 0.361
pin 4 - 1.58v 0.004
pin 6 - 13.55v 0.56
