820-3115-B NOT POWER
tipoti
hello,
There is a green light but it won't turn on. stays at 0.02 amps
PPVRTC_G3_OUT = 3.3 voltage
PPBUS_G3H = 12.57 Voltage
HS_COMPUTING_P = 12.57 Voltage
HS_COMPUTING_N = 12.57 Voltage
SMC_RESET_L = 3.4 Voltage
SMC_BC_ACOK = 3.4 Voltage
PP3V3_S5 = 3.3 Voltage
ALL_SYS_PWRGD = No voltage
Q7950 I removed it but it's the same
ALL_SYS_PWRGD how much voltage should i read
should i inject voltage from outside?
tipoti
PCH_SRTCRST_L : 3.3 VOLT
PPVRTC_G3_PCH: 3.3 VOLT
RTC_RESET_L :3.3 VOLT
PPVOUT_G3_PCH_DCPRTC : NO VOLT
PPVRTC_G3H : NO VOLT
i use the same charger i always use
The strangest thing is getting two RTC signals, when no RTC power present.
I bet you didn't make good contact, or didn't test in correct point.
PPVRTC_G3H_PCH and PPVRTC_G3H are not the same in your schematic?
Two other RTC signals not posted yet.
tipoti
PPVRTC_G3H =3.3 VOLT
PCH_INTVRMEN_L :3.3 VOLT
PCH_INTRUDER_L : 3 VOLT
PCH_srtcrst_L : 3.3 VOLT
PPVOUT_G3_PCH_DCPRTC :NO VOLT
I hope I read the right place. If wrong, can you write your full name please?
tipoti
U7941
Pin 1 : 3.4 volt PP3V42_G3H_PWRCTL
pin 2 : 3.4 volt SMC_PM_G2_EN
pin 3 : 3.4 volt P5V3V3_REG_EN
pin 4 : 0 P3V3S5_EN_L_R
pin 5: GND
pin 6: 3.3 volt PP3V3_S5_PWRCTL
pin 7: 0.031 volt S5PGOOD_DLY
pin 8: 0.031 volt S5_PWRGD
tipoti
pin 5: GND
pin 8: 3.4 VOLT S5_PWRGD
there is an orange light, the battery is charging. 1.57 amps, but the PP5V_S3_REG voltage comes and goes. After 5 volts, the zero fan turns and stops.
tipoti
Before bypassing the fan was spinning slowly and stopping. When bypassing, the fan keeps spinning at full speed and repeats the same thing over and over.
tipoti
PPBUS_G3H : 12.12 volt fixed
PP3V42_G3H_REG :3.4 Volt fixed
PPVRTC_G3_OUT: 3.3 volt fixed
PP5V_S5_LDO : 4.9 volt fixed
PP5V_SUS_FET : 4.9 volt fixed
PP5V_S3_REG: 5 volt and no volt . 5 volt and no volt. repeats
P5VS3_EN_L : no volts when the fan turns 3.4 volts when stopped
PP5V_S3_P5VS0FET : no volt
PP3V3_S3_P3V3ENETFET : 3.2 volt and zero repeats
P3V3ENET_SS : 1 volt and zero repeats
Check for voltage on the big coils too.
Also check power rails from pages 71 & 72.
Check diode mode to ground att any rail which doesn't get voltage pulse.
