820-2850 green light no fan spin
Modder1
PPBUS_G3H = 8.38
PP3V42_G3H= 3.39
SMC_RESET_L = 3.42
SMC_BC_ACOK= 3.19-3.29 but jumps around there a lot.
I am of course unsure what to do now.
thanks in advance for any help!
Modder1
I already did ultrasonic, and now I flux and heat u7000 but still same. Should I replace u7000? sorry for being such a jerk.
Modder1
R7021/22=16.3 R705/52=8.3 to me it looks like u3301 is missing entirely. not sure if it is supposed to be there on this board. also nothing at j2600
kind regards
jadao
Hi did you fix it by replacing the resistors?
as the schematic mention 10/10ohms and 0/2.2ohms for 21/22 and 51/52 sensing resistors.
Modder1
i get beep on 21/22 and 52 but 51 i get 2.4. this mean I should change 7021, 7022, and 7052?
kind regards
jadao
7051 at 2.4 ohms is ok
7052, you say beeping, I assume 0 ohm, OK
7021 you say beeping, I assume 0 ohm, NOT OK
7022 you say beeping I assume 0 ohm, NOT OK
7021/7022 NOT OK because schematic shows 10 ohms and you get 0 ohm.
To answer your question, 7021/7022 are not 10k ohms, they are 10 ohms! As per schematic.
10k ohms means 10x1000=10000 ohms.
You had before 16.3 and now it beeps...
Check again resistor values of course without power.
Check also traces as asked by Duke
Modder1
changed 7021/22 with 10K resistor and still same measurement on those. Can't seem to understand where to find equivalent to 7051 on an 820-2530 which is where i pulled the 10K from
Modder1
ok so, on r7021/7022 i get 10.2 when i have the multimeter in Resistance mode. I was measuring in diode test mode before -fml and 2.4 and 0.2 on 7051 and 7052. but for sure my reading on ppbus_g3h is 8.38 and pp3v42_g3h is 3.42 -does this mean pp4v4w_g3h is present?
I have also got these measurements with the original 10ohm resistors and removed the 10K resistors. I am really sorry guys, I hope you can bear with me.
Measure between pins 17/18 and 27/28 to ensure the sensing traces are ok. If that is ok then ISL may be bad. PPBUS needs to be 12.6V
Modder1
17/18 u7000 = 0.03
27/28 u7000 = 0.14
unless I am supposed to be in resistance mode again and in that case between 27/28 u7000 = 20.3
17/18 u7000= 3.13
