For $29/mo, we provide access to advanced level technicians who will answer your questions on any Macbook board related matter to the best of their knowledge promptly & walk you through how to solve your problem so you can deliver a working board to your customer.
i press and maintain power button, then connect charger, NO GREEN LIGHT, then release charger... same thing, fan spin up and down, the different is this time the fan spin higher and louder.
Nothing shown on the screen.
Symptom same as before changing C9560.
No history available, board looks very clean, untouched, not tampering sign
If you means " Misc Power Supplies" and " Power FETs", then I have checked and they all cycling too, except of course PP1V05_S5 because U7740 does not exist.
PPBUS_G3H and 3V3_S5 are stable. There is no 3V3_SUS signal on this board.
When the board is in the machine, how come it doesnt wait for me to press the button before it try to power on? as long as the magsafe is plugged, the fan will start spinning up and down, with the front led going on and off at the same time...
If you are able to detect pulsing all the other voltages, should not be a problem to detect 1V05_S5 too.
More than that, this voltage comes from 3V3_S5, which you said is stable.
Post diode mode to ground (at 1V05_S5).
" 1.05V S5 LDO Ibex Peak-M requires JTAG pull-ups to be powered at 1.05V in S5. Pull-ups (3) must be 51 ohms to support XDP (not required in production). 70mA is required to support pull-ups. Alternative is strong voltage dividers (200/100) to 3.3V S5, which burns 100mW in all S-states. "
Are we looking at the same page? Bottom right "PAGE 77 OF 132/SHEET 71 OF 101" ?
no there is no 1v05 there on another 2850, diode mode also read 1... perhaps these are only meant for the jtag and not required in production(as it said)?
PCH has internal pull-ups for JTAG signal, in theory this circuit is only required to actually use JTAG when debugging. Some board models still have it populated.
