820-01041 wake up problem
bartech
after battery change after some time there was short on J6951 and after that when you close laptop and opel lcd dont wake up, mac work there is sound and touchbar is woking.
i change j4800 and j4801 but still the same.
bartech
yes but sometimes nedd some time to change to 0v, one time i use only one magnet and go to 0v on left and right
If machine has sound and working touchbar, it wakes up.
You may have problems only with image, or backlight.
bartech
still same, i check and found that you cant change brightness i try to change on touchbar but nothing change stay as same brightness.
When it put screen to sleep and switch off i can wake it up by power button and it wake up the screen
Still not clear if missing only backlight, or image too.
"9-0v
10-0v"
F8400 burnt?
Check diode mode to ground at R8400.
bartech
sorry check again when for sure there is data
problem was that there is apple logo and than black screen when i check
1,2 - 0v
4-0v
5-7,38v
9,10 - 17,10v going up slowely stop at 18,90
11- 9,47
12-0v
15-7,23v not stable
16-7,23v not stable
17-5,10v
18-7,80v
19-0,27
21-42v
22-0v
"21-42v"
Seems that you have over 50V at backlight output.
Possibly open LED strip connection; check the voltage directly on the T-CON board.
Check for continuity between D8410 & J8500.
bartech
check on j8500 continuity all ok
on 25 and 27 i got 1580 on multimeter
on 31 and 33 - 1780 on multimeter
d8410 all ok
bartech
at t-con of lcd
pwr 3,37
avddn 5,44
avddp 5,44
rst-3,33
cclk-3,33
tms-3,33
5v-5v
vst 11,95
1v8-1,8v
tdi-3,3v
vcmp-0,6v
tmscl-3,3
imscl-3,3
wp-3,3
rest 0 v
On some point of T-CON, you should get 50V aprox; near the backlight connector.
If not, change the small video cable.
BTW, always check in diode mode with red probe connected to ground!
