820-01041-A With liquid damage It does not turn on
1phone.cl
Hello
I got a Macbook Pro with liquid damage in the sectors
L9021
C9081
C9593
C9592
The damage is only on the edges of the motherboard
I did a cleaning but the Mac does not turn on, this is the first time that I work with this motherboard and I am lost, I do not know where to start
1phone.cl
yes a tried to restore with another T2 Mac and apple configurator but I got an error, the one I sent you in the photo.
I had to remove some caps that had corrosion damage
C9592
C9593
C9081
and I haven´t put them back because I do not have these cap at this time
Do you think the failure could be related to that?
The mentioned caps shouldn't be related; all of them are filter caps.
Do you get correct voltage on SSD coils?
1phone.cl
yes i have the correct voltage on SSD coils, some of them have a little of damage corrosion, but it is only on the top not at the base where they are soldered.WhatsApp Image 2022-01-12 at 10.53.52 (1).jpegWhatsApp Image 2022-01-12 at 10.53.52.jpegWhatsApp Image 2022-01-12 at 10.53.51.jpeg
1phone.cl
There is some possibility of discarding by taking memories, this mac has 6 memories and I have a good reballing technique, so just tell me what I have to do and I do it.
I recommend to check first all the resistors from SSD area.
One corroded resistor is enough to block the communication.
Check the basic signals of U9000.
1phone.cl
ok, I already checked the resistances related to ssd and they are all good, I tried again to restore and now it gave me another error
How can I check the basic signals of the U9000?
