820-00850-A - Tries to turn on and restarts
mushr00m
820-00850-A
It tries to turn on
appears the Apple logo and starts loading and the it crashs and keep in a loop
Customer told that before brings to me it appears even the login screen and then crash
Doing visual inspections the board looks fine
Is it board issue or the disk is crashed and needs to be reinstalled with the Apple Configurator?
Which measures should I take?
If no important data, go for DFU restore.
You can try DFU revive anyway; it doesn't erase SSD.
To save data (at least intenting), try to connect in Target Disk mode.
mushr00m
Yes. Acutally I need the data!
DFU revive in target disk mode. OK
Will look for a complete youtube tuturial. If you have one please let me know!
mushr00m
Just assemble again and now it turns on all the time and goes to question mark folder
Using option to enter it there is no SSD drive.
Do I still need to use Apple Configurator and try revive?
DFU and Target Disk mode are totally different things.
Seems to have SSD problem, if is not even recognized now.
All SSD power rails are good?
Change security settings and boot from USB macOS.
Then check if appears on Disk Utility, at least.
You can also check in Target Disk mode.
mushr00m
I tried booting into recovery mode it after it loads the recovery mode it restarts loading the recovery mode system and the crashs and its in a LOOP doing that
Didn't check SSD power rails yet
How to change security settings and boot from USB macOS? Is it possible to use high sierra USB stick?
mushr00m
I tried both using USB stick with High Sierra and Recovery Mode
Both FREEZES the screen and did NOT go to the next screen where I have the options to reinstall the system, disk management and etc.
What should I do?
mushr00m
Just to give sharp detaisl
With USB stick connected through adapter it freezes as soon as the disk option appears and the icon of loading right besides wifi get stuck
Recovery mode its loads normally the first stage and the next stage when start to load it restarts
mushr00m
Tried with windows but the exactly same behavior happens with any USB stick
Appears apple logo as usual
Then change to disk selector and freeze instantly
The loading icon get stuck right away
If I turn ON without any USB connected it goes to disk selector and then put after its stable on disk selector it works but freezes on the next step
Any other way to check and/or fix this board?
mushr00m
What do you mean by recover the data?
I am not even able to enter the disk utility after turning the machine ON
The SSD does not appear on the DISK SELECTOR screen even when one or other time it arrived there without FREEZING!
Then data is already lost.
You can try DFU restore, just in case.
If still not possible, then SSD is really bad; may need to change the NANDs...
mushr00m
Update
Did the DFU restore and still almost the same issue
Tried both Catalina and High Sierra known working USB stick that I have
They are not FREEZING anymore but as soon as I choose them it goest directly to the globe icon and wifi selector to go to recovery mode which still in a loop and not acessible
What do you think?
Any other test? Replace NAND? or entire board?
