For $29/mo, we provide access to advanced level technicians who will answer your questions on any Macbook board related matter to the best of their knowledge promptly & walk you through how to solve your problem so you can deliver a working board to your customer.
Draws 5volts 0A
Ppbus_g3h=0v diode mode to ground is 0.436.
Pp3v3_g3h=0v diode mode to ground is 0.367.
All CD3215 has the same reactions..
u7000 voltages:
PPDCIN_G3H_CHGR=5v
TBA_VDDA=5v
TBA_BOOT=4.7v
AUX_DET=1.2v
PM_EN_P3V3_G3H1.889v
SMC_RST_L=0V
CHGR_A/BMON=0V
You can't get PPBUS_G3H without 3V3_G3H.
So you have a problem on the 3V3_G3H power rail, after R6915.
Try injecting 3.5-4V there and use IR camera.
It allows you to detect small temperature differences.
Remove CPU heatsink first and disconnect any cable from the MLB.
But system not detecting battery..
I have tried testing with another battery the system doesn't display on screen and draws 20v and trackpad stops bouncing.
