Hi,
I've got an A2442 model which was previously liquid damaged. Liquid damage was only at the MagSafe side of the board, mostly around the SSD, and at the audio amplifyers. After cleaning the board with IPA, and an ultrasonic bath, almost everything was working fine, for a few months. The few not working functions were, the left side audio, the Touch ID sensor, and the 2.4GHz communications were realy slow (the Bluetooth and 2.4G wifi). This was fine with me I did'nt bother to fix these issues.
Until one day the laptop not allways charged from the MagSafe port, no green light either, but it was charging properly from the typeC ports. Then it started to drain the battery overnight, even in standby mode. And at one point, I even couldn't charge the device after this overnight drain.
I opend the machine up again, to try to fix this power issue, but now I'm a little bit stuck. PPBUS_AON is fluctuating at around 6.9V, see on the image bellow:
PP3v8_AON tries to get up at 3.8 V, but at the valleies of the PPBUS_AON it fails and that voltage also drops, I assume the 3v8 line is created from PPBUS, so it could be OK.
Also PPDCIN_AON stays only at 5V. This is the same either with a MagSafe, or a TypeC port.
I also found out that U7700 the PMIC is getting a little bit hot at the CPU side. Unfortionatly I don't have a thermal camera, so I only "measured" this with evaporating IPA.
In advance, I appreciate any help.
Bálint Kostyál
Bálint Kostyál
