A1990 AmrestoreErrorDomin Error-9 trying to restore with configurator 2
Soji
20v without battery
PPBUS 13v is present
3v3_g3h is present
All voltages around cd is present
It will show this error and flash apple logo and goes back to dfu.
Soji
I’ll check for ssd voltages
Faults. Yes
The macbook came in with 5v, I changed one resistor around u7000 and 20v came. The Macbook trackpad is clicking but no apple logo, black screen.
I now try to restore it with configurator 2.
then this error 9 came.It’s permanently on dfu now.
Soji
PP2v5_nand_SSD0 is present
PP1v8_SSD0 is present
PP0v9_SSD0 is present
20v 0.05a going back and forth to 0.00a on the ampmeter
Soji
Nothing happened still no apple logo. But the track pad clicks for a while and stop and start again and stop
Trackpad click is not a sign of life.
Once actuator is powered, you will sense the force feedback.
But is just a hardaware response, no need the board to boot.
Check if board voltages are steady, or restarts at the moment when trackpad click is not present.
Do you have 3 identical boards, with exact the same symptoms?
Soji
Around the usb c controller ic u3200
Pp3v3_upc_xb_ldo is steady
Pp3v3_g3h_rtc_x is steady
Ppbus_g3h is steady
Pp1v8_slps2r is steady
5v is missing though
Voltages are steady. The once I have checked so far.
yes 3 different board drawing 20v no life.
If you get 20V on all USB-C ports (without battery), then no problem on USB-C areas.
Do you have 820-01814 boards?
For the future, please post board model on the title, or first post.
Did you try both revive and restore options in DFU?
Revive doesn't erase the SSD.
Soji
Yes. It gives me error 9. The macbook will flash apple logo with a progress bar. With error 9
It’s 802-01814-01
If you get Apple logo and progress bar, SSD is initialized at least.
This doesn't discard an internal problem; maybe some bad NAND.
Can you get access to it in Target Disk mode?
No need to press power button for this machine.
