A1707 no backlight
Dozer
Hi, got this A1707 with no backlight, only when open a little bit i can see the display.
so I found here in the Rossmann Wiki this
by the way the black film it can be more clean and easy removed with fine sandpaper instead of scratching with the knife
I tryed that and I have Display now but it looks like every second LED on the bottom is only working
Did somebody had that before?
is the problem here the display or a better guess a bad soldering?
It tryed already 2 times with 2 new cables but always the same result
need some help please
Dozer
Problem solved, there was another crack in the cable, so i connected like in youtube and some jumper wires then from the junction until almost where the cable is coming out of the screen, hell that was a solder trip! :-) ok, but its working now, thanks for help.
