sekidata
This A2337 Air came in "water-damaged", but the only evidence of liquid exposure was on the USB-C plugs, which were badly corroded. With a fresh USB-C board, the machine chimes but only shows a blank screen (backlight is on). On an external display, the screen flashes on and off, showing the cursor on a black background. Intermittently, the machine will display and attempt startup and I've gotten it to load Recovery Assistant once (and verified that the machine does not have activation lock).
I've tried A DFU Restore, which successfully ended in a padlock on the host (but no video on the target Mac).
Do you have a BIN file for reflashing the SoC ROM?
