00165 missing PM_SLP after ultrasonic
Alright, this one kept me up all night.
Have an 820-00165 that came in with corrosion in a few places, namely around U7600 and R1673 area. Was missing S0_CPU originally, replaced a resistor for S0 cpu power (can't remember which one, sorry) and that fixed it, managed to boot into os and everything. Also replaced a few other corroded components, tested again, still working fine. Put board in ultrasonic to clean, a few hours later after drying board won't start, I get green light and S5 rails, but no S4. Also missing PM_SLP_S5/S4.
I have 32khz clock and pp3v3_sus, but it doesn't seem like PM_SLP_S5 or S4 pulse when triggering SMC_ONOFF.
I'd really appreciate some advice, feel like I got stuck. Thanks
Possibly knocked off component; especially if you didn't use sweep function on UC.
Broken trace is also possible.
Check the signals involved in power on sequence.
Hi! I did use sweep function, but still, sometimes things happen I guess.I've had another look at the board and I can't really see anything ripped off.
I'm sorry, I'm not intimately familiar with the power on sequence on these. Where can I find it/what signals should I be checking?
Check PM_BATLOW_L, PM_RSMRST_L and RTC signals.
Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L.
If yes, check for pulse at PM_SLP_S4_L at same time.
[TABLE="width: 759"]
[TR]
[TD]PM_BATLOW_L[/TD]
[TD]3.316V[/TD]
[TD] [/TD]
[/TR]
[TR]
[TD]PM_RSMRST_L[/TD]
[TD]3.287V[/TD]
[TD] [/TD]
[/TR]
[TR]
[TD]RTC_RESET_L[/TD]
[TD]3.313V[/TD]
[TD] [/TD]
[/TR]
[TR]
[TD]PCH_SRTCRST_L[/TD]
[TD]3.313V[/TD]
[TD] [/TD]
[/TR]
[TR]
[TD]PCH_INTRUDER_L[/TD]
[TD]3.023V[/TD]
[TD] [/TD]
[/TR]
[TR]
[TD]PCH_INTVRMEN[/TD]
[TD]3.214V[/TD]
[TD]PCH_INTVRMEN_L not found[/TD]
[/TR]
[TR]
[TD]PM_PWRBTN_L PULSE[/TD]
[TD]3.412V NORMALLY, DROPS TO 0.345V WITH ONOFF[/TD]
[TD] [/TD]
[/TR]
[TR]
[TD]PM_SLP_S4_L PULSE[/TD]
[TD]NO PULSE, 0.02V[/TD]
[TD] [/TD]
[/TR]
[/TABLE]
"PCH_INTVRMEN_L not found"
Does not even exist...
I suppose PM_DSW_PWRGD is OK, if you really have 3V3_SUS; and implicitly PM_SLP_SUS_L, of course.
PCH_DSWVRMEN also present?
Trigger SMC_ONOFF_L repeatedly and monitor all PM_SLP_Sx_L signals.
Is better to use an o-scope, it can catch any fast pulse.
If still no pulse, heat PCH with quality flux...
yes sorry, think PCH_INTVRMEN_L is on other boards.
I'll check all signals and report back. if I heat PCH, should I clear edge bonding on cpu first, or just flux and boil at 150-200C as it is?
Thanks
You can remove edge resin on PCH side; not really needed, but not too complicated.
Don't search for PCH_INTVRMEN_L on any board; good enough if you find PCH_INTVRMEN...
so, I kinda got busy with other jobs and put this aside for a week. Yes I have PM_DSW_PWRGD at 3.4v and PCH_DSWVRMEN at 3.2v.
Still can't see any pulses on pm_slp_s5, s4, s3. I have one of the small "pocket oscilloscopes". I know they're generally junk but I've used it before to see pm_slp pulsing, so I should be able to see the pulses here too.
I removed the CPU edge resin and heated with amtech 559 at 200C for about 1-2 minutes. Sadly no result from this. Maybe my amtech is fake (from ebay) but it's worked well for normal soldering and cleaning corrosion.
Anything else I can try? It kills me that the board was working before going into the cleaner, never had it kill a board before
Possibly brokem trace, or knocked off component in cleaning process.
I don't see other option, if board worked before UC...
