820-03286 (Air A3114 2024 M3) with no keyboard/trackpad
Not sure which chip may be involved only with this issue.
Sometime bad flex can cause such problem; you've said already tested.
One friend mentioned he directly changed all small chips related with trackpad; the ones placed under the border shield, near the connector.
sekidata
Because that's where the original liquid damage occurred, I already replaced all small chips near the connector (level shifters and load switches) from a donor board.
So you're saying that at this point nobody understands the trackpad/keyboard/haptic circuitry and bus signals enough to pinpoint a failure here.
sekidata
Update: I finally figured this one out. For haptic feedback and the keyboard to work, the interrupt signal IPD_MCU_INT_CONN_L must be fully functional, in addition to the 4 SPI bus lines. The interrupt signal from the CPU (IPD_MCU_INT_L ) was there, but the level shifter UT340 was not correctly translating the signal to the trackpad. Replacing UT340 a second time restored haptic feedback and keyboard function.
An oscilloscope really was a must in tracking down this hard-to-diagnose loss of function.
