For $29/mo, we provide access to advanced level technicians who will answer your questions on any Macbook board related matter to the best of their knowledge promptly & walk you through how to solve your problem so you can deliver a working board to your customer.
The machine has no signs of liquid damage. USB meter shows 5V 0.16A. PPBUS is 12.3V. PP3V8_AON is present. The main PMU (U8100) does not produce any power rails, it appears to be off despite good input power. What signals are required to turn it on?
After removal of U8100 I noticed that PP3V8_AON is 50Ω to ground. Enough resistance to produce 3.8V but probably not enough to power either PMU. I'm assuming that without a good thermal camera, this short will be impossible to find?
After replacing the SPMU (U7100) the machine gets 20V and chimes. However, it is stuck in a boot loop and never fully starts up.
DFU Revive fails with error 21 and sometimes 9. DFU Restore fails with unknown error 4042. Am I correct assuming that the NANDs are likely bad and need to be replaced?
